      01-10-2011, 12:32 AM   #1
Markel
Drives: 2005 X3
2005 X3 hestition at 2.5 -3 rpms...
My X3 has developed a hesitation or stutter when the tach is between 2.5 and 3 and it's under a medium load. No one can figure it out. The dealer first said it was because I have "non BMW approved" tires on the car, and now after push back from me is suggesting a transmission replacement. I really don't think that's the problem, and my private mechanic agrees. Has anyone has similar problems? Any suggestions? I'm at my wits end.
Many thanks!
      04-06-2011, 05:04 PM   #2
FISHER-X3
Drives: 2004 X3
Filter
Check air filter, mine was doing same with dirty filter. K
      04-06-2011, 05:06 PM   #3
FISHER-X3
Drives: 2004 X3
[QUOTE=FISHER-X3;9306049]Check air filter, mine was doing same with dirty filter. K
      04-12-2011, 04:56 PM   #4
soshrillitsill
Drives: 2004 BMW x3
I had this as well... dont know why but it went away. When it gets really hot out (i live in vegas) it does that some times idk why. when it happened i would roll to stop an then start to accelerate but it seamed like it was going to just shut down so i had to baby it but it went away must have been a bad are to gas mix but why would that just go away and not stay? not sure if this helps lol
      06-16-2011, 05:01 AM   #5
Botwin
Botwin's Avatar
Drives: 2015 WRX Limited
This happened to my car twice. The first time at 72,000 miles, they determined it was the DME, which they replaced. The problem was solved.
At 135,000 miles, it happened again, but replacing the air filter solved it. I am now at 181,000 miles and have not had the problem since.
Tags
x3 hesitation
