      04-09-2019, 08:19 PM   #1
94vtirozguy
Drives: 2013 X3 F25 (N20)
Engine hesitation
Noticed recently that after coming to a stop and starting to take off there is a hesitation.
I have just done the 60,000 mile service.
Replacing the spark plugs does not seem to have fixed the issue. I run 93 octane fuel all the time, so assuming clogged injectors is not the issue.
Any thoughts?
      04-11-2019, 08:22 AM   #2
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
Ignition coils likely. Different car but similar case, I have a Cayenne Turbo S and I noticed the car suddenly felt like it had no balls accelerating. I thought it was a boost leak at first but turned out after replacing the spark plugs I did not push the coils all the way down on the plug. They were making good enough contact not to throw a miss-fire CEL but under the G forces while accelerating the would lift off the plug and not make good contact.
Give your coils a firm pushing or consider replacing if problem persists.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      05-02-2019, 01:26 PM   #3
Sfkjeld
Drives: 2007 X3
I had this exact issue. The more load you put on the engine, the more hesitation and even bucking. Finally threw an engine misfire code. Replaced the coil in the #2 cyl, car runs like new!
