      01-08-2020, 11:35 PM   #1
TCHBMW
Drives: BMW X3
Hello,
I'm trying to update the software on my 2015 X3 via USB. When I reach the 'Update Software' screen, I'm prompted with the following message (also pictured):
'Operation currently not available. Please try again later'
I only have the option to Cancel.
Does anyone have any ideas to how I can complete this software update?[IMG][/IMG]
      01-09-2020, 08:17 AM   #2
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
not enough info for others to help you:
- what file did you put on your USB?
- is it in the root folder of your USB?
- How is your USB formatted?
- Which USB port did you plug it into?
- Is the engine on or not?
- What version is already installed on your X3?
      01-09-2020, 09:41 AM   #3
TCHBMW
Drives: BMW X3
Thanks, najnad. Please see my asnwers below:
UPD05081.bin
UPD05081.bin is the only file on the USB flash drive, there are no folders or any other files.
FAT32
The USB port in the center console
Engine off, but ignition (Start/Stop button) switched on
Media: MN-002.045.001
Phone: TN-002.045.001
Please let me know if there's any additional info I can provide.
      01-09-2020, 10:49 AM   #4
najnad
najnad's Avatar
Try the USB port in the glove compartment
      01-12-2020, 03:39 PM   #5
TCHBMW
Drives: BMW X3
I searched the glove compartment for a USB port. No luck. I even pulled out the two little cover plates in the compartment to see if there was a port behind them. Everything I've read online suggests the only USB drive on the 2015 X3 is in the center console.
      01-13-2020, 08:48 AM   #6
najnad
najnad's Avatar
sounds like you might have gotten a corrupt file somehow and/or bad formatting. I would try the following:
1. Reformat the usb stick FAT32 using a PC (not mac)
2. Re-download the bin file from BMW to your computer
3. Save the bin file to your USB stick
4. try loading again into your vehicle
good luck
      01-13-2020, 08:55 AM   #7
najnad
najnad's Avatar
and if you have another USB stick, try using that one...
      01-13-2020, 08:58 AM   #8
najnad
najnad's Avatar
from another post:
"Notes:
1. Some USB drives come with a hidden partition at the front of the drive. Make
sure to go into Disk Management (for Windows) or Disk Utility (OSX) and delete all partitions.
Then recreate a single partition formatted FAT32 (Windows) or FAT (OSX, it's FAT32 by default).
2. For Mac users, OSX places a series of hidden files on the USB stick which may cause the NBT not to properly read the data, if you have this problem
use a utility like Blue Harvest to remove all the hidden files/folders from the USB stick."
      01-15-2020, 09:06 PM   #9
TCHBMW
Drives: BMW X3
USB Software Update - Operation Currently not available, please try again later.
I bought a new flash drive and followed your formatting instructions. I was able to successfully install the software update on my X3, thanks for your help, najnad!
      09-02-2021, 11:03 AM   #10
Randy54123
Drives: BMW 328I 2015 M Performance
Question Software Update
I have a 2015 BMW 328i and the software option is not available to click , bluetooth only works for calls (no media) and no navigation, ANY HELP PLEASE! Thanks
      09-03-2021, 12:58 PM   #11
najnad
najnad's Avatar
Do you have enhanced Bluetooth? https://www.bimmerfest.com/threads/2...etooth.979606/
      09-24-2021, 01:25 PM   #12
Randy54123
I do
      09-27-2021, 11:18 PM   #13
scorilos
Drives: 2014 BMW X3
Nav maps and SW update
Hi TCBMW,
What was the source of your bin file? I tried downloading it from BMW website but it does do it.
I would like to update my NAV maps and the software - NAV maps are 2013 version! I would appreciate your help!
