      05-13-2022, 06:44 AM   #1
RNdX
Netherlands
Drives: F26 X4 2.0Dx
Driver side rattle
I could use some help.
I have this annoying rattle in my BMW
(I bought this car two weeks ago)
I have already secured the computer modules under the steering wheel with velcro.
I checked under the hood, checked wipers and windscreen, A-pillar and
checked front left wing bolt's
Next step i will remove hood lever and trim.
And maybe doorpanel..
In the video i was recording different places to find the rattle, i think the rattle is more downwards.
Sounds like metal shield, trim clip or plastic.
Anyone any ideas?
Edit: Also with parking brake on you can here the rattle (with the resonance of the car)
https://www.youtube.com/shorts/U_yrkciO_h8
      05-14-2022, 01:18 AM   #2
pole1980
Drives: BMW X3 F25 & BMW X1 F48
I also have a super annoying rattle, that was tracked down to the air intake pipe, it's only present though only at standstill, like when I am at a stop light, goes away when rpm increases above idle.
the air intake pipe is poorly designed and it vibrates, resonates inside the car.
Not sure if it's your case though, sounds like it is something actually inside the cabin, maybe door panel?
