      05-05-2022, 08:58 AM   #1
deltaplaned
Drives: e46
Driver's Rear Mirror doesn't turn on reverse gear
When reverse gear is engaged, the side mirrors lower slightly and turn towards the car, minimizing the “blind” zone.
So, the right mirror turn towards, but the left don't.
Is it correct or must be coded additionally?
      05-05-2022, 01:03 PM   #2
Wgosma
Drives: 2012 F25 X3 28i (N52)
I believe only the passenger side mirror will tilt downward; driver side mirror will not.
      05-06-2022, 04:03 AM   #3
deltaplaned
Drives: e46
thanks, what app do you use, or if you can, give me the code to view in E-Sys.
thanks!
and additional question..
if the passenger doesn't sit down, the led "AirBag for passenger 2 is OFF" is on.
if the passenger sit down, the led will off.
Is this the correct statues?
Can be coded to be always the led in off?
      05-06-2022, 07:13 AM   #4
Wgosma
I'm using BimmerCode app.
I don't think you can code the airbag, yours is I believe operating properly.
      05-06-2022, 09:07 AM   #5
deltaplaned
Drives: e46
probably I cannot code the airbag.
because I am newbie in X3, I dont know how must be.
can you verify to your car, is the same LED always ON?
      05-06-2022, 09:30 AM   #6
Wgosma
In overhead console, the airbag warning lamp is illuminated if passenger seat is not occupied.
