08-01-2021, 11:13 AM | #1 |
Rep 20
Auto Engine stop/start feature makes brakes squeal
I have noticed lately that the brakes give a god awful squeal when slowing to a stop. It almost sounds like a siren. I have heard brake squeak before, but this sounded different. I did suspect the brakes as it only happens when slowing to s stop and as soon as the car is stopped, the noise stops.
I replaced the back brake pads because they were worn down and needed it. The awful sound was thill there. The front brake pads are getting thin, but they still have some life on them. Then suddenly I noticed that the horrible sound goes away when I turn that fuel saving feature off. So it appears that the auto engine off/on feature is causing this horrendous sound when braking to a stop. Does this feature have a tie into the braking system? If so, it is back or front, or both? Im kind of at a loss for troubleshooting this. A google search didn't yield any real results. Any help would be appreciated. |
08-02-2021, 07:00 AM | #2 |
Rep 265
There is no interraction between auto stop/start and the car braking system. If your braking system is making noises that bad you should inspect it immediately and minimize driving, there could be something significant in need of repair/replacement.
08-02-2021, 07:23 AM | #3 | |
Check out my Youtube @n55david!
1306
Rep 3,554
Drives: 2017 m240i, 2015 X3 x35i
you have brake problems, go get them fixed
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
08-04-2021, 08:42 AM | #4 |
Rep 3,651
If you have low speed brake squeal, look up "bed-in" procedures and give one a try. Basically clean off the brake surface. The really low speed / light brake pedal pressure squeals come from everyday driving if you don't occasionally get aggressive on the stopping.
If it's not directly related to your speed when you use them (i.e. idling along at 5mph in both cases with the feature turned on and off) then you might have a different noise altogether that you think is from the brakes. Belt related most likely. |
CAX36.00 |
08-04-2021, 10:54 AM | #5 | |
Rep 21
CAX36.00 |
08-05-2021, 06:56 PM | #6 |
Rep 2,564
AFAIK, the F25 M vehicles have the same exact brakes as non-M, actually, besides the cosmetic differences, the M has the same performance as a non-M. It's not a true ///M, that's why there's no ///M badge on the rear.
08-07-2021, 12:37 PM | #7 |
Rep 20
Thanks for the replies. I think I have found the problem.
Its the PCV valve on the valve cover. It makes this god awful squeal, but only when the auto start/stop feature is turned on and I am rolling to a stop. Thats why I mistakenly thought there might be some connection between the auto start/stop feature and the brakes. I realized it wasn't the brakes when I turned that feature off and the noise immediately stopped. I was able to find a video of someone with the same issue on YouTube. Ill put the link below for anyone who find this thread and has the same issue. Thank you all for the replies. |
09-03-2021, 06:28 PM | #8 | ||
Rep 21
09-03-2021, 08:21 PM | #9 | ||
Rep 2,564
