06-14-2022, 04:19 PM | #1 |
Rep 2
Higher mileage 2012 N55 vs Lower mileage 2014 N20
I'm looking to buy my first BMW (and luxury vehicle); my two choices are a 2014 X3 xDrive 28i with 88k km, or a 2012 X3 xDrive 35i with 140k km. Cars here cost double the amount of anywhere else, so both of them are around $35k USD
Everyone says to avoid the N20 from those years, and that they have timing chain problems, and the N55 seems to be universally admired. I've seen both vehicles in person and they're pretty well kept. Generally speaking, maintenance costs seem to be less than what they are in the US in terms of labor (I was told the dealership here charges $70/hr).. parts will likely have a 15-20-30% premium. Which one would you get? |
06-14-2022, 04:46 PM | #2 |
Rep 1,906
I'd pass on the 4-banger…..those motors had issues with timing chain guide failures in the years prior to 2015.
https://www.bimmerpost.com/forums/sh...php?p=22428084 Go with n55 in-line 6👍 |
John1460.00 |
06-14-2022, 06:54 PM | #3 |
Rep 120
Assuming equal routine scheduled maintenance for both, I'd go with the N55 in a heartbeat over the N20. You should be able to get many more miles out of it.
Pat
2015 F25 X3 35i M Sport - Carbon Black |
John1460.00 |
06-14-2022, 07:02 PM | #4 |
Check out my Youtube @n55david!
1296
Rep 3,533
Drives: 2017 m240i, 2015 X3 x35i
N55
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
John1460.00 |
06-17-2022, 09:24 AM | #6 |
Rep 2
Seems like it's been taken care of. I got the dealership maintenance logs and it seems to have gotten a service every year/~10k km or so. There's a 2yr/11k km gap between 2020 and 2022, but I'm assuming that'd be COVID related.
Engine seems to have undergone a complete rebuild/disassembly (unclear from logs) in 2013 at 35k km.. nothing but routine service since (oil pan gasket seems to be biggest thing since)... sounds normal? |
06-17-2022, 09:43 AM | #7 |
Rep 1,906
Oil pan gasket is not a small job, leakage not that unusual however. Perhaps you can get more detailed info about the engine rebuild, that seems an unusual repair at such low mileage. I generally have used BMW I buy pre-purchase inspected but independent Euro car mechanic, I'd recommend that in this case. You don't want to buy a car with potential problems, worth the money to pay a mechanic to look the car over before you buy.
John1460.00 |
08-28-2022, 06:10 AM | #9 | |
Rep 2,599
08-28-2022, 06:26 PM | #10 |
Rep 114
You couldn't give me an N20.... Not to mention the N55 spanks it hands down powerwise...
And if the oil pan gasket has been done??!?! Half the maintenance work is done... I'd question if the oil filter housing gasket has been done, and the valve cover and gasket...and serpentine belt/tensioner.... Beyond those the N55 is almost bulletproof. |
08-29-2022, 01:46 AM | #11 |
Rep 119
I have a 13 X3 with the n55. Basically been trouble free for the past 60k miles I've had it besides regular maintenance and replacing parts that are known to go bad (thermostat, water pump, oil filter housing gaskets etc...)
I'd go with the n55. |
