      06-25-2020, 11:23 AM   #1
rt-man
Drives: 2016 X3 xdrive35i
Coolant Flush
Hello, can someone direct me to a DIY thread for this or direct me to an existing thread? I'm sure one exists already. Can't figure out where to drain it...no petcock (old school) or drain plug or radiator main cap that I can see. 2016 X3 35i
I already bought OE BMW coolant. Thanks.
      06-25-2020, 01:29 PM   #2
evilchargerfan
evilchargerfan's Avatar
Drives: 2012 F25 (N55), 2014 I01 (REX)
seems like they want us to drain by removing the hose and spilling it
Draining coolant:
Release sealing cap on the coolant expansion tank.
Release and detach coolant hoses (1) at radiator .
Drain, catch and dispose of coolant.
https://www.newtis.info/tisv2/a/en/f...check/EQpQ78sM
      06-25-2020, 01:34 PM   #3
evilchargerfan
not sure if you've already replaced your expansion tank .... but here, just in case:
https://www.newtis.info/tisv2/a/en/f...rts/1VnYm43pwu
Once you're all done playing with coolant and hoses, dont forget the self bleed procedure
  • Fill expansion tank slowly with the 50/50 coolant mixture.
  • If bleed screws were opened, close each as the coolant begins to come out of the bleeder.
  • Once the bleeder on the expansion tank (if equipped) is flowing coolant and has been closed, fill expansion tank to the lower edge of the filler neck.
  • Install the coolant cap.
  • Connect a battery charger to the battery or jumper cable ports under the hood.
  • Turn ignition to the ON position. If equipped with a START button, push button (with key fob installed or active), but do not depress the brake or clutch pedals. This will turn the ignition on, but not crank the starter.
  • Set heater temp to MAX and blower to low speed.
  • Press the accelerator pedal to the floor for 10 seconds.
  • The self bleeding procedure will begin (via the electric water pump) and will run for about 12 minutes. During this time the water pump will alternately turn on and off. Do not remove cap while bleeding procedure is running.
  • When bleeding is complete, double check coolant level and adjust as required. Replace coolant cap.
https://blog.bavauto.com/12402/bmw-a...cement-how-to/
      06-25-2020, 01:37 PM   #4
evilchargerfan
ONE MORE THING. The hose at the bottom of the expansion tank is beyond brittle. I think I broke mine simply by sneezing on it. I bought 1 to have on deck, just in case ... and I did end up needed it / using it
17128651298 - Coolant Recover Hose
https://www.fcpeuro.com/products/bmw...ery-tank-hose-
x3-17127601859
Wgosma806.00
      06-25-2020, 02:52 PM   #5
383vett
383vett's Avatar
x3-17127601859
Been there, done that.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      04-01-2021, 01:44 PM   #6
Wgosma
Drives: 2012 F25 X3 28i (N52)
I'm getting ready to drain/re-fill my cooling system. Car has N52 (normally aspirated) engine. I'm wondering about this 'pull the hoses off the radiator' business??? Both the main hoses look like they connect quite a distance above the bottom of the radiator, so I'm wondering if that is best place to drain?
I got under the car, see pic - there is one smaller hose that connects to raditor very near the radiator's bottom/lowest point. I'm thinking this would be THE hose to remove.
Thoughts/comments/recommendations, etc.. ?
Thanks/Bill
      04-02-2021, 12:42 PM   #7
Wgosma
Thanks/Bill
Did coolant drain and refill...here's the BMW (blue) Lifetime fluid at 92K miles, hmm......
      04-02-2021, 07:11 PM   #8
383vett
383vett's Avatar
Wow, your waterpump still going after 92K?
2021 SQ5
      04-02-2021, 07:21 PM   #9
Wgosma
original pump still ticking right along!
      08-24-2022, 09:41 PM   #10
guarodc
Drives: 2015 BMW X3 xDrive28i
Thanks/Bill
Hi Bill - Was that one finally THE hose?
      08-25-2022, 12:57 AM   #11
Wgosma
Thanks/Bill
As I recall now, the radiator actually had a small drain cock down low on passenger side- did not remove any hose.
      08-26-2022, 07:27 AM   #12
Dekero
Drives: 2013 BMW X5 35I
That looks like oil contamination...
Have you replaced your Oil Filter housing gasket?? If not at 92k miles it's def. Due... And only going to get worse... At this point you need to drain and refill with water and degreaser( 4-8oz ) run the bleed procedure and drain... Repeat till the water comes out clean... With a final rinse of only water... Then drain and refill with coolant... Only after you've replaced the OFHG..
Ask me how I know all that.... Yeah it was a mess when the OFHG finally blew out completely and the low oil pressure warning scared the shyt out of me...
Turns out oil pressure is higher than coolant pressure this why the oil enters the coolant and not the other way around...
      08-26-2022, 07:30 AM   #13
Dekero
Mine made it to 181k and was still going when I replaced it while the engine cradle was off the car, so it made it easy access from the bottom... No way I wasn't going to take advantage of that time to replace...
Same thing about the starter when I replaced the HPFP...
You want a great reliable BMW.... It's a labor of love and a shyt ton of maintenance... Wait for it to break and it will break you.
