06-20-2018, 11:21 AM | #1 |
Rep 40
Anyone running on 235/55/18 tire size
Has anyone switched to 235/55/18 tire size? Change in diameter would be 2.2% I have read up to 3% difference is okay for the sensors. I want to increase the side wall abit and found tires running wider than average so the tread width would be even more than the stock pirelli's 245's. Thoughts?
Current - 2011 x3 35i/BMS Stage 1
Previous - 2008 Montego Blue 135i/M-sport /BMS-DCI/Cobb stage1 aggressive /235s Potenza s04 Pole Position - 265s Potenza RE11 /ATE TYP 200/EBC Yellow Stuff/NGK 5992s/Slotted and drilled rotors |
06-20-2018, 08:05 PM | #2 |
Rep 3,544
06-21-2018, 11:02 AM | #3 |
Rep 40
The tread of 235 Firestone Indy 500 is wider than the tread of 245 RFT Pirellis our vehicles come with according to Tire Rack at least, but that is irrelevant to me. I just care if I would have any problems running this size tire 235/55/18. Thanks!
06-22-2018, 03:37 PM | #4 |
Rep 3,544
I can't give you first hand experience but I feel pretty confident that small of a change would be meaningless. We've got a lot of room in our wheel wells and it's unlikely BMW would be willing to cut anything that close on anything other than a race-bred M3 or something.
I've been looking into another set of wheels off and on for the last few months and people are getting away with bigger tires (255's) and some big offset changes (=/- 10mm or more) and still not having problems. Not combined but either / or. Any chance you can test fit the tire or get a guarantee from the seller / installer? Also, even if the tire width in reality is a bit off from the stated size, the profile (i.e. 45, 50, 55) might still be right on compared to that stated size. Last edited by tracer bullet; 06-23-2018 at 03:37 PM.. |
06-22-2018, 04:45 PM | #5 |
Rep 71
Not 235's but I switched to a slightly taller tire than stock recently. Went to 245/55/18's and they are fine, no issues. I wanted to correct my speedometer as it used to read slightly faster than actual speed, also wanted to fill in the wheel well a bit better. These did the trick.
06-23-2018, 12:20 PM | #6 | |
Rep 40
06-23-2018, 12:22 PM | #7 | |
Rep 40
06-24-2018, 03:13 AM | #8 | |
Rep 1,524
06-25-2018, 11:33 AM | #9 | |
General of the Space Forces
171
Rep 721
06-26-2018, 07:40 PM | #10 |
Rep 71
Couple of pics attached. They're actually winter tires, I replaced the old RFT's with them and had planned to get a set of aftermarket 20" rims and tires but just never did and left these on year-round. They're Goodyear Eagle Ultra Grip GS-2's.
I've had them on for about 15,000 miles now and they don't show much wear. They run nice and smooth at speed, they're a bit rougher at lower speeds during turns when those teeth on the sides hit the pavement. |
