      09-20-2016, 09:37 AM   #1
Amber
Drives: 2012 X3 Sport 19" rims
Motor air filter
I have seen on youtube that you can actually remove the motor air filter, wash it,then re-install after it drys out.
Has anyone done this rather than buy a new filter.
      09-20-2016, 10:18 PM   #2
guyver626
Drives: 2014 35i m-sport carbon black
Just get a new filter. It's cheap enough where you can afford to do it right. The only filters I've heard you can wash is the aftermarket like injen or AEM products. And you may need to spray them down with oil.
      09-28-2016, 01:54 PM   #3
BigJake
Drives: 2019 X3M40i
Yeah, don't bother. I just replaced mine for $19.
      10-02-2016, 07:04 AM   #4
MichiganMike
Drives: 2016 X3 xDrive 35i
2020 X3 M40i  [0.00]
2016 BMW X3 35i  [0.00]
I agree the risk/reward for cleaning a relatively inexpensive engine air filter is not a good trade-off. The fine particulates trapped in the pores of the OEM air filter will not easily be removed by washing, so effectiveness of a re-used filter is likely reduced even after washing. If the filter is unknowingly damaged during this cleaning process, you increase the risk of dirty air by-passing the filter and causing serious and expensive problems down the road. There is also the potential to invalidate a possible warranty claim in vehicles still under warranty.
Consider the information at the link below:
https://www.quora.com/Can-a-car-air-...f-replacing-it
      10-02-2016, 12:55 PM   #5
Amber
Thank you I will buy new
