      01-16-2021, 06:01 PM   #1
ClampThurst
Drives: 2018 M4-Silverstone, 2017 X3
X3 F25 camshaft pattern
Replaced the valve cover gasket on my 2017 X3 3.5i and saw this pattern on the cam lobe. Wondering if this is normal or sight of abnormal wear.
      01-17-2021, 09:33 AM   #2
Wgosma
Drives: 2012 F25 X3 28i (N52)
Looks unusual; have you had any issues in past with how the motor runs? (valve clatter, misfiring, etc.)
How many miles on the car?
See pic, unfortunately camera not focused properly but as I recall the lobes on my car's camshaft (this is actual pic at 85K miles, N52 motor) were very smooth; certainly noting like what's shown in your pic.
      01-17-2021, 11:31 AM   #3
383vett
383vett's Avatar
I replaced my valve cover last year and didn't notice those lines. Wear lines would obviously run parallel to the lobe. They look like original machining marks but I would think they would be polished by now. Can't help. Sorry
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      01-17-2021, 12:01 PM   #4
pungo
pungo's Avatar
I've seen a lot of cams but have never seen one with those patterns. Is every single lobe like that? Can you feel them with your fingernail. Really strange
      01-17-2021, 01:58 PM   #5
ClampThurst
Every single on was like that. The feel of the lobes is absolutely smooth. The engine runs great and has 62k miles on it. Will be doing an oil analysis ASAP to see if there is metal in the oil.
      01-17-2021, 02:06 PM   #6
pungo
pungo's Avatar
I doubt anything in valve train caused that pattern. I'd think the cam spins way to fast for something to cause it. Maybe it's a newer machining method from the factory to improve oil lubrication
This is a new one for me and I'm curious to know the answer.
Wgosma806.00
      01-17-2021, 02:09 PM   #7
ClampThurst
Upon further analysis, this might just be the original forging lines of the metal. The pattern continues even on the edges of the lobes, the part not in contact with the lifter arm.
Wgosma806.00
      01-18-2021, 12:01 PM   #8
KC87ZB
KC87ZB's Avatar
305
Drives: 2023 M2
Looks like forging striations to me. Shouldn't have them but I don't believe you are going to see longitudinal stress that would cause the camshaft to "lengthen" and separate. We need a metalurgist to comment to be certain but I doubt an issue.
      01-18-2021, 12:41 PM   #9
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
nope, looks fine
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      01-23-2021, 04:09 PM   #10
ClampThurst
I just saw the same pattern on another N55 engine valve cover gasket DIY on this forum. Must be normal for this cam.
      01-23-2021, 05:00 PM   #11
BMW JA
Drives: 13 X3, 73 454 Vette,
I am not an engineer!
Looking at it it would seem that the pattern, although smooth to the touch, is? ground that way to serve as micro oil galleys?
