02-02-2012, 02:51 PM | #1 |
Rep 79
Rear break pads done after 15000 miles
Idrive computer is saying my rear brake pads need replaced after only 15000 miles !? Front ones are saying still 8000 miles to go
Don\'t understand this. Can Anyone else check their brake pad wear indicator in vehicle settings for a similar mileage and let me know what it says Thanks |
02-02-2012, 03:04 PM | #2 |
Rep 876
Not that unheard of. These vehicles really like to drag the rear brakes. This is done to keep the X3 level and not squat too much when braking. It ties back to the electronic brake distribution. Now when you brake really hard EBD will transition much more braking effort to the front which will allow you a shorter stopping distance. Before the EBD days, in most cases, cars would brake evenly across all 4 corners and as such the fronts would carry the brunt of the braking but again you got some nose dive depending on how hard you want to stop.
In my truck, which does not have EBD, I have replaced the front pads 3 times now but have only done the rears once at like 60,000 miles. |
02-02-2012, 03:10 PM | #3 |
Rep 143
Also performance control triggers a lot of rear braking. When cornering at certain speeds, the inner rear wheel gets some braking to ease the turn.
(Sorry for the terms I use, I believe I can speak a good english, but mechanical terms are not always easy to find for me) |
02-02-2012, 06:43 PM | #4 |
Rep 12,276
BMW replaces them for free within the warranty period, so take it in and get them replaced.
I think it is bad luck to be superstitious |
02-02-2012, 10:18 PM | #6 |
Rep 157
I have close to 11,000 miles on my car. Fronts are saying pad replacements in 45,000 more miles and rears in 20,000 more miles. At that rate, my warranty will be up before I get new front pads.
02-03-2012, 02:32 AM | #7 |
Rep 350
Is it really that you get new pads as a warranty coverage? In here warranty does not apply to normal wear and tear.
If I burn my tyres "drifting" all day, I will not get new tyres |
02-03-2012, 04:14 AM | #8 |
Rep 1,876
On a previous 330i they wore out earlier than expected and they replaced pads and rotors on all four under warranty. Dunno if that was right, or if anything's changed. Was very pleased with that at the time!
02-03-2012, 07:17 AM | #9 |
Rep 80
Nobody mentioned in this thread the main reason for accelerated rear pad wear so here it is:
The more you use the cruise control the faster your rear pads will wear out since the rear brakes are used to prevent the car from going faster than the set speed, particularly when going downhill or when reducing the set speed via the adjusting wheel on the steering wheel. When reducing the set speed this way the car will brake with the rear brakes until it reaches the new set speed. |
02-03-2012, 11:24 AM | #10 | |
Rep 157
I've never used the cruise control. Might start using it to wear down my brake pads when I get closer to 50,000 miles. |
02-03-2012, 12:52 PM | #11 |
Rep 554
Drives: 335D MSport 2016
I have 50,000 miles on my passat and haven't changed the pads yet. I don't like braking, it slows me down!!!!
02-03-2012, 01:43 PM | #12 | |
Rep 3,855
They aren't cheap either
02-03-2012, 02:02 PM | #13 |
Rep 128
Drives: 2012 X3 XDrive 35i
Somebody correct me if I'm wrong, but I thought these things are not covered under warranty. In the US at least, it is the maintenance plan that covers this and that is included as standard in the purchase of all new US (at least) BMW vehicles.
02-03-2012, 02:13 PM | #14 | |
Rep 876
Now they could catagorize it as warranty repair if they dealer finds there is a stuck caliper or something else but for the most part brake pads fall under the maintenance plan same with things like wipers, oil etc... |
02-03-2012, 04:02 PM | #15 | |
Rep 12,276
As to those comparing mileage and break wear.... apples/oranges. Brake wear has nothing to do with mileage on a large scale comparison. I drive almost 100 miles roundtrip on my commute, and if lucky I touch the brakes maybe a dozen times total - almost all highway miles. But if you do all or mostly city driving, and brake aggresively (like last second red-light stops, etc.) you're going to wear them out fast. I've never owned a vehicle long enough for it to need brake work.
02-03-2012, 04:14 PM | #16 |
Rep 764
Had this problem on a Jag a few years ago. As it turned out the car was designed to engage the rear brakes before the front brakes to mitigate front diving under hard braking. Perhaps.....
02-04-2012, 07:55 PM | #17 | |
Rep 325
Drives: 2011 X3 xDrive 28i
Wear and tear of brake pads, rotors and windshield wiper blades not covered in Canada..... |
02-04-2012, 09:12 PM | #18 | |
Rep 51
Myself, I would like to ask that you stay in the forum and let the forum administrators deal with the people who break the forum rules. |
02-04-2012, 09:30 PM | #19 | |
Rep 114
02-04-2012, 10:40 PM | #20 | |
Rep 29
02-05-2012, 02:10 AM | #21 |
Rep 3,855
To add a qualified of defence of Lotus:
I have read probably 95% of his posts on this forum, even stuff I'm not really that interested in, and he often responds to praise modestly and states that much of the information and diagrams supplied are just copied and pasted from various sources like RealOEM and the user manuals. I don't think he tries to pass it off as his own, he just adds his knowledge and opinion and it's very insightful, useful and interesting. Sometimes it's just his own opinion and people are entitled to disagree. I just think in this case his comment was misconstrued and it turned into a little rant which I now see has been removed which is probably a good idea on reflection but that email doesn't get deleted too unfortunately And even when someone has just straight copied and pasted from another source and not added their own thoughts, it has still taken them time and effort to post and it saves other people time so it should be welcomed as part of the forum IMO. And yes, this last paragraph is because it's often exactly what I do!
F25 xDrive20d SE __ professional multimedia package | dynamic package | climate package | 309s | xline | xenons | electric seats | folding mirrors | business speakers Last edited by sfax; 02-05-2012 at 02:12 AM.. Reason: typo |
02-05-2012, 04:01 AM | #22 | |
Live for today tomorrow never comes
1989
Rep 9,498
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
