      10-23-2020, 12:46 PM   #1
chileno
Drives: BMW X3 F25
Do I need a new EPS rack?
Chassis stabilization malfunction / 4x4 error
      10-23-2020, 05:30 PM   #2
383vett
383vett's Avatar
If you are having no symptoms, I would make sure the battery is fully charged, clear the codes and see if they come back. How many miles on the car?
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      10-23-2020, 09:47 PM   #3
pungo
pungo's Avatar
Does it drive/steer ok? You need to properly diagnose the issue(s), not just replace parts and hope it resolves the errors, that can get expensive.
      10-30-2020, 05:34 PM   #4
FranzX3M
Drives: '13 X3M
Is the steering heavier than usual? I had to replace the steering shaft because the universal joint was binding. Expensive part but 3-4x less than a steering rack.
