02-29-2024, 08:34 AM | #155 |
Rep 999
I would recommend checking tire pressures and potentially lowering them. If you don't fill the car with 4 passengers and a trunk load of cargo you really don't need 38-40psi in the tires. I always run 34-36 and it's much more compliant.
pdotc8412.00 |
03-03-2024, 09:13 PM | #156 |
Rep 6,916
03-03-2024, 11:12 PM | #157 |
Rep 5
Drives: bmw x3m competition
Anyone powder coat 892M wheels?
Does anyone have pictures of a X3MC with 892M power coated wheels in silver? I'm tired of black wheels and think silver would look great with Brooklyn grey. Thanks.
03-03-2024, 11:13 PM | #158 |
Rep 5
I found the PS4S to be much better than the stock tires.
03-04-2024, 08:03 AM | #159 | ||
Rep 2,554
Gxs615's BC HCA 386 on Brooklyn Grey - https://x3.xbimmers.com/forums/showp...63&postcount=1 larsmin's BBS LM on white - https://x3.xbimmers.com/forums/showp...postcount=1232 bylkylov's HRE Classic 300 images on blue- https://x3.xbimmers.com/forums/showp...&postcount=108 |
03-04-2024, 12:04 PM | #160 |
Rep 373
Max Well any wheel/tire combinations running wider than 275 up front?
03-04-2024, 12:10 PM | #161 |
Rep 475
If you don’t change the brake pads to IS1500/2000 they will turn black in a couple of hundred miles 🤣
2022 X3MC
2020 330iX Daily 2002 R34 Mspec Nur -in Canada 2014 S4 APR stg1 444hp retired 2010 335d; 2004 WRX wagon; 1994 300ZX -retired |
03-04-2024, 12:14 PM | #162 |
Rep 475
To do that you need wider rims and that will cause major strut/suspension damage. There was a thread here where a dealer installed OEM size rear wheels up front by mistake that caused major damage.
2022 X3MC
03-05-2024, 05:42 AM | #163 | |
Rep 2,554
Vettethret : Total F97/98 for Vossen HF-5 (21x10 ET33, 21x11.5 ET41)/Pilot Super Sport (285/35 R21, 325/30 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...08&postcount=6, https://x3.xbimmers.com/forums/showp...&postcount=112 for more images and his order sheet showing the ET and comment regarding use of H&R 15mm spacers, and for this set on his new X4MC described in his thread 16 Dec 2023 - https://x3.xbimmers.com/forums/showthread.php?t=2068626 . Vettethret : Total F97/98 for Vossen VFS-1 (22x9.5 +21, 22x11 +12)/PS4S (285/30 R22, 315/30 R22) - wt N/A yet https://x3.xbimmers.com/forums/showp...0&postcount=11 and https://x3.xbimmers.com/forums/showp...47&postcount=1 JLT : Total F97/98 for Vossen HF-5 (22x9.5 ET18, 22x11 ET21)/Continental ExtremeContact DWS 06 Plus (285/35 R22 square) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=199 and https://x3.xbimmers.com/forums/showp...&postcount=198 |
5LEEPR_G01508.00 |
03-05-2024, 08:08 AM | #164 |
Rep 455
03-09-2024, 08:10 PM | #165 |
Rep 20
Thoughts on the fitment
I made a post recently about having an 2023 x3m with pirelli scorpion all seasons but I realized there not all season. They are Pirelli scorpion winter tires. I am thinking on running MICHELIN PILOT SPORT ALL SEASON 4.
The fronts 265/40/21 the rear 295/ 35 / 21 with the stock 892m rims. Also would I be able to sell these winter tires they are in pretty good shape. |
03-14-2024, 04:28 PM | #166 | |
Rep 2,554
https://x3.xbimmers.com/forums/forumdisplay.php?f=719 |
03-17-2024, 10:00 AM | #167 |
Rep 345
Just ordered a set of Rohana RFX11 for my x3m. 20x10 et25 front and 20x11 et30 rear. These offsets give me a deep concave in the front and super deep in the rear. Will be running 275/315 setup for tires. Will update with photos once everything arrives and installed.
Max Well4806.50 04detroitls64.00 |
03-17-2024, 02:51 PM | #168 | |
Rep 2,554
BlownLSX : Total F97/98 for Rohana RFX11 ? Gloss Black or ... (20x10 ET25, 20x11 ET30)/? PS4S or ... (275/40 R20, 315/35 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=167 {Ft wheel/tire: ? lbs, Rear wheel/tire: ? lbs} {Separate wts - Ft wheel: ? lbs, Ft tire: 29 lbs, Rear wheel: ? lbs, Rear Tire: 33 lbs} |
03-26-2024, 10:38 AM | #169 | |
Rep 345
Max Well4806.50 |
03-26-2024, 11:51 AM | #170 |
Rep 2,554
Thanks for sharing - I've got your info entered in the List. Since the Atturo site shows tire wts, if you do ever have your wheels off and can weigh them even with the tires on I can use Atturo's wts to get est'd wts for the RFX11s.
03-27-2024, 10:22 PM | #171 | |
Rep 291
Max Well4806.50 |
03-28-2024, 06:06 AM | #172 | |
Rep 2,554
BlownLSX226.50 1nityrider58.50 |
03-28-2024, 03:47 PM | #173 | |
Estoril Tings
76
Rep 437
Drives: 2020 X3M 2018 X3 M40i
2018 X3 m40i - MHD Stg 1
2020 X3M - Stock |
04-10-2024, 07:53 AM | #176 |
Rep 113
New wheel setup on.
Brixton RF10’s on Atturo AZ850’s. 21x11 +25 rear - 295/35/21 21x9.5 +20 front - 265/40/21 Good bit of aggressive stance on the rear but doesn’t poke obnoxiously far, no rubbing. Next is lowering springs. Side note, if anyone has red calipers and wants to trade for blue, I’m down! |
Max Well4806.50 |
