03-12-2023, 03:32 PM | #3587 |
Rep 8
Hi witch esys and psdzdata is best to do it and how to configure it to avoid bricking NBT unit
currently using esys 3.30.1 and psdzdata 4.32.15 full Could you please PM link to the software if update is required Thanks in advance Jack |
03-12-2023, 03:35 PM | #3588 |
Rep 42,932
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
03-18-2023, 03:19 AM | #3589 |
Rep 5
Help - unable to read FA
I have an F39.
The vehicle was stolen and recovered and the thieves took the head NBT head unit. Why - I have no idea... but the problem I had was that the speedo was not working. So I put the car into a local BMW expert, and when I got the car back the speedo works, but I get multiple errors (airbag, etc) and now I cannot do anything via E-Sys. Well, I am able to connect but unable to read FA. I get a PSdZ Error: No FP could be generated from FA "". [C002] Not all elements of the FA were found in the FA2FP: SALAPA 550 [72] I have E-Sys 22.06.01 (64 bit) - powered by TokenMaster's Launcher PRO5.2.4 I can see that several SALPA elements have been changed. I think this is causing the issues. I have a backup of the FA from prior to taking the X2 to the BMW expert. How do I restore the backup FA to the vehicle when I can't connect via E-Sys? Thanks |
03-18-2023, 10:00 AM | #3590 | |
Rep 42,932
Under E-Sys Options, check box for "Update VCM after TAL execution" then load backed up FA into coding module and VO Code any ECU.
03-27-2023, 12:51 AM | #3591 | |
Rep 5
VO now restored to its original. Thanks! Can you recommend someone who can help me with some remote coding? I need to clear the vin from the head unit, assign it to my vin, program HU, change country and set it up with nav, etc. I think it's beyond my basic skills! PM me if you have a suggestion. Thanks again. |
03-27-2023, 08:39 AM | #3592 | |
Rep 42,932
Sorry, but I really do not know who is offering Remote HU Retrofit Coding.
04-15-2023, 01:09 AM | #3595 | |
Rep 42,932
04-18-2023, 04:30 AM | #3596 | |
Rep 3
shawnsheridan it looks like your the guru here? Do you have any guides for esys and what would be needed? I have an enet cable, esys and full psdz. I’m just concerned that if I plug a new head unit in the car it will enter locked mode because the vin won’t match? Any help would be greatly appreciated. Many thanks Mike |
04-18-2023, 09:34 AM | #3597 | |
Rep 42,932
04-18-2023, 11:01 AM | #3598 |
Rep 1
Radio problems
Hello shawnsheridan!
I have an issue with the radio not booting proporly, i see that you are i charge here off the esys software. Could you help me please? |
04-18-2023, 11:02 AM | #3599 |
Rep 42,932
PM sent.
05-05-2023, 02:09 PM | #3600 |
Rep 35
Hi ShawnSheridan,
I have an old version of E-Sys (3.27.1) and PSdzdata (V58.0) but it wont install on my upgraded laptop (was running XP, now running Win7). I used this old software on my 2013 X3 30d some years ago. It keeps trying to generate tokens, even though it has just generated a token the step before. It seems the E-Sys Launcher cant find the token. Is there a newer version I should be using? Many thanks. |
05-05-2023, 03:33 PM | #3601 | |
Rep 42,932
05-05-2023, 03:51 PM | #3602 |
Rep 3
I have an active Connected Services package that includes Active RTTI. All online services include automatic map updates, weather, etc. seem to be working fine but the traffic only shows on few roads. It shows traffic only on a very few highways but nothing on other major and other streets. I’m wondering if this can be fixed with coding. Previously activated full screen Apple Care Play through 3rd party. Didn’t get much help from Connected Drive Support. Did troubleshooting steps and signal resend, nothing worked.
05-09-2023, 10:47 AM | #3604 |
Rep 42,932
PM sent.
05-11-2023, 04:23 PM | #3605 |
Rep 2
shawnsheridan your name keeps on coming up for the master solver of enhanced bluetooth queries so here goes -
Just got an X1 e84. Has combox in boot. BMW advise me after giving them the VIN the current setup is 6nh. What is the easiest method to getting music streamed through bluetooth? If album art could be displayed that would be a bonus. If it helps I have idrive and an SOS button on the roof. I have (hopefully) attached a picture of the NAV Settings screen. Please help! 🙏 |
05-11-2023, 04:27 PM | #3606 | |
Rep 42,932
05-11-2023, 04:36 PM | #3607 |
Rep 2
05-11-2023, 04:45 PM | #3608 |
Rep 42,932
I can't advise in detail, as I don't do any E-Series work. You would need to use NCS Expert and SP-Daten and a K+DCAN Cable is all I can tell you.
