12-27-2012, 09:25 AM | #1 |
Rep 87
Tire sizing question ?
Hello,
My OEMS on my 2011 28i are 245/55/R-17 . Came across a set of Winter tires and Tirerack sports wheels of size 235/RR/R-17. The only difference I see is in treadwidth . Using http://www.1010tires.com/tiresizecal...?action=submit revealed Revs per Mile: 753.3 on 245/55/R-17 Revs per Mile: 765.5 on 235/55/R-17. ----------- Do i need to be concerned? Appreciate any input. Thanks |
12-27-2012, 10:29 AM | #2 | |
Rep 12
tire will look small in the wheel arch so better stick to oem size or go taller by 5pct using 235/60 |
12-27-2012, 06:48 PM | #3 |
Rep 510
To answer your specfic question - there should be no problems in using 235/55/17s in place of 245/55/17s. There is only a 1.6% difference in tire overall diameter (27.6" for the OEM tire vs 27.2" for the replacement). Only issue will be your speedo will read 1.6% high - ie when speedo shows 60 mph, you actually will only be going approx 59 mph.
The alternative suggested by DC will also work. I know because thats the tire size I replaced my original OEM 245/55/17s with when I took delivery of our X3 over 12 months ago. For the 235/60/17s, tire diameter is 28.1" or 1.8% larger than the OEM size (in this case the speedo reads 1.8% low). One other alternative which will let you keep the BMW OEM tire diameter is 225/60/17 (tire OD = 27.6"). Tony |
12-28-2012, 03:25 PM | #4 |
Rep 12
Yes but we need to remember that usually speedometers do not show real speed (go faster) so increasing the diameter will bring us to actual speeds
Have seen x3 with a f10 M5 wheels and 255/40/20 tires that is .... something Sorry not 17" |
12-29-2012, 02:39 PM | #5 | |
Rep 87
