05-01-2012, 08:55 PM | #1 |
Rep 114
tailgate opens itself?
this morning i parked my x3 outside my office, opened the tailgate to get my briefcase, and pressed the close-and-lock button. i walked away without watching, but noted the beep signalling the doors were locked before i entered the building. when i went outside after work, the tailgate was wide open. this is the second time this has happened. i recall an earlier thread on this subject, but haven't been able to locate it with the search. is anyone else experiencing this?
05-01-2012, 09:20 PM | #2 | |
*Bimmerpost Plasti Dip Guru*
83
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
you might want to take this to the dealer for safety reasons from the public. especially when your doing your grocery, because little children might get hit when walking by, get sued after. I do work my body and i have to say, that the tailgate when it opens, its really strong like, your carrying around 40-50lbs. |
05-02-2012, 04:24 AM | #4 |
Rep 1,876
I haven't noticed what it does if it encounters and obstacle. Does it open back up? Any chance it ran into something that prevented it from latching and opened up?
05-02-2012, 09:07 AM | #7 |
Rep 325
Drives: 2011 X3 xDrive 28i
Mine sometime will open back when there are obstacles. Sometimes when the stuffs is just blocking the tailgate a little bit, it won't open back.
05-02-2012, 09:13 AM | #8 |
Rep 315
In my experience its usually always because you've caught the button the fob unintentionally
F25 xDrive 20d M Sport in Alpine White, Pro Nav, Auto 'Box, 19" Wheels, Visibility Pack, Heated Seats, Reverse Cam w/ Top View, Sun Protection Glass, DAB radio
05-02-2012, 02:34 PM | #10 |
Rep 1,781
Sometimes when I press the close and lock button or lock the car and then press the close button after, it will close and beep when shut, but then beep again and open back up. Seems that the locked latch might be tripping the obstacle sensor.
05-02-2012, 07:58 PM | #11 | |
Member
Rep 12
I hit the lock button (comfort access), tailgate swings down, car beeps, I turn around and it starts beeping again and the gate opens up. It took me about 5 sec to realize what was going on and that I didn't have the key. Nice feature to keep from locking yourself out. Any chance your key fob or spare key is inside the car? |
05-03-2012, 08:38 AM | #12 |
Rep 128
Drives: 2012 X3 XDrive 35i
Interesting. I've had valets lock the fob in the car with no problems (door not locking or tailgate opening.
My wife would join me later with her fob or I can unlock the car with the iphone. |
05-03-2012, 09:12 AM | #13 |
Rep 63
This has happened a number of times with mine.
I had been blaming the wife - bad move !! All too easy to think the button has been pressed accidentally but - I discovered that when it occurs the lid does not fully open to the top of its normal open position. If it were an inadvertent button press it would. On one occasion we were close enough to hear an alarm beep inside the car, as it raised up, immediately before stopping. It also seemed to then go into a strange mode where it would not close with the remote but needed a press on the tailgate button. Do you have that? The car is currently with the dealer on long term test (I'm out of country for 5 weeks so quite a good time for that). Unfortunately it has not occurred for them. Yet. One other "feature" I noted is that it "always" seems to happen just a few minutes after switching off and closing the tailgate. I am thinking there may be an interaction between the software closedown sequence and the comfort access. Big problem is the rare intermittent nature of the issue - all too easy to blame yourself (or the wife!) It has only happened to us 4 times in a year but is a major concern if it might happen when the car is parked up for a few weeks in a public place (like an airport carpark) Hopefully we will just have to check 10 minutes after parking to be sure - I do not hold a great deal of hope that the dealer will find it - can't afford to leave the car for a 3 month test ... but this is an ideal occasion where a large number of us can test. You are not alone! |
05-03-2012, 09:27 AM | #14 | |
Rep 114
05-12-2012, 06:19 AM | #15 |
Rep 63
Dealer has been unable to reproduce the fault under test but has ordered a replacement instrument cluster. All the comfort functions run through the cluster and the two proven reproducible faults after it came back open were:
1. The lid would only operate through the tailgate button not the fob and 2. that the LED display at the instrument base was completely blank after the tailgate stuck. After the car had been switched off long enough to fully power down everything appeared to return to normal. If we had not been nearby when it happened the last time, it would have powered down, reset then appeared perfectly normal. Just luck that it happened when we could "catch" the fault, near to the dealer, and could demonstrate it. And to have a dealer that would properly check it out and take action. |
