04-26-2024, 11:06 AM | #1 |
Rep 2,214
Noisy whistle when x3 AC is on
Currently about to buy that x3 35i. On the test drive I observed a rather noisy whistle which I located coming from the HVAC vents.
Is this a tell tale sign it will need an AC air compressor? Curious if anyone had this happen yet? |
04-26-2024, 12:02 PM | #2 |
Rep 327
Drives: E46 M3 & LCI X3 35i M Sport
I'm not sure about a whistle, but I've heard conflicting information on the "whine" the compressor makes. Some people say it's happened to them for years and BMW says it's normal, others say it just needs a refill and the noise will go away.
Unsure if this is what you mean or not. |
04-26-2024, 12:36 PM | #3 | |
Rep 2,214
04-26-2024, 01:29 PM | #4 |
Rep 327
Does the noise change with the rev’s or the engine?
Under the assumption that we are talking about the same noise, and after doing all of the research I’ve done I don’t think I would be turned off by that. Now, this is also assuming that it’s a good deal, the car is what you want, this is one of the only perceivable things that is wrong. Mine makes noise sometimes and is dependent on the “a/c” button being ON. Does my air blow any different? No it’s working great, and I live in hot South Florida. |
04-26-2024, 02:49 PM | #5 |
Rep 1,940
Make a note to your mechanic to check this when he does the pre-purchase inspection....there are very few things on any vehicle that cannot be diagnosed and repaired.
04-26-2024, 03:28 PM | #6 |
Rep 2,668
Drives: Z4MC, X3-35i,525i, Corrado G60
You're not going to hear compressor noise through the vents, but rather in the engine bay near the compressor. Have a professional determine the cause of the noise, could be an inexpensive or very expensive repair.
Seeing as you don't work on cars, depending on the PPI results, you may be better off spending more money and purchasing a newer vehicle with way less miles since this one could end up costing a lot in repairs and maintenance in the near future |
Wgosma840.50 |
