01-10-2024, 04:55 PM | #1 |
Rep 25
Help Needed! Can't remove the hose between water pump and engine block
My '13 X3 w/ N20 engine currently has 117k miles. It has mostly been problem free except for oil housing gasket leak at around 65k and the timing chain guide shattered at 80k miles.
I am currently doing the waterpump and thermostat change. And I figured that since I am down there I might as well just replace all the hoses. Right now I am not able to remove the hose between the water pump and the engine block. the 3-way hose is only stuck on with the engine. I removed the bolt on the flange but no matter how hard I pulled, it just wouldn't move. I spray WD40 on it everyday for the past 3 days. Below are the photos. Any advice on how to remove this darn thing? |
01-10-2024, 05:41 PM | #2 |
Rep 1,046
Since you are going to replace it, give it a lengthwise slice with a box cutter bat the flange.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
Don T3.00 |
01-11-2024, 01:22 AM | #3 |
Rep 25
The flange is very hard plastic, how do you cut it with box cutter? Also, after the flange is cut, would't it run the risk of leaving the male part of the hose inside the engine block receptacle?
01-11-2024, 05:55 AM | #4 |
Rep 120
If it were me I'd get a heat gun and warm the area where the plastic flange and the block mate. Once warm, start tapping on it with a dead blow hammer. My guess is that there's some gasket sealer/adhesive that's cemented the part in place. Good luck.
Pat
2015 F25 X3 35i M Sport - Carbon Black |
01-11-2024, 01:28 PM | #5 |
Rep 25
Great advice!!! Originally I thought that the heating will expand the plastic way more than the Aluminum engine block and will make it tighter fit so I never tried heat it up. But your perspective of the gasket cemented in the engine warrants this trial. will report back on how it goes.
01-12-2024, 08:01 PM | #6 | |
Rep 25
Errr..... the heat gun didn't work. I checked all the DIY videos and nobody is messing with this hose on their N20. |
01-18-2024, 12:02 AM | #8 |
Rep 95
I just did the same thing, including radiator so I feel your pain and frustration. I had hell getting it off myself but finally managed after doing several things including tapping carefuly with a hammer just to knock the connection loose, also used dawn soap and lubricated the connection point with it, I then got a large set of channel locks with a grip large enough to grasp the entire connection point, wrapped a washcloth around it to prevent metal to plastic contact and damage. Grabbed it with the channel lock pliers and and just shifted it back and forth, up and down and side to side to jar the connection loose and it finally broke free. Just be sure to remove any dawn soap residue for obvious reasons, the dawn did come in handy when It came time to reconnecting it. I poured a couple of drops onto my finger and rubbed it around the fittings and it helped it slide back on, it actually helped alot and would have been hell attaching it without it. Channel locks were the key, along with the soap.
tracer bullet2545.00 |
01-20-2024, 03:40 PM | #9 | |
Rep 25
Thanks again for chiming in! And I hope future folks could benefit from these discussions. |
