12-10-2021, 12:41 AM | #1 |
Rep 135
Unable to find Software Update
Hi guys, I have a 2016 X3 and I am trying to check if there is any available update for my car (CIC) but when I input my VIN on the official website below, I get a general error message.
Any clues on how to make this work o how to check if my car has the latest software update? Thank you https://www.bmw.com/en/footer/software-updates.html Also, is it true that if you need to replace the valve cover gasket, you need to replace the valve cover too? I think I am getting scammed by my BMW dealer, seems pretty unreasonable to spend this much money for a gasket change, especially since there is nothing wrong with my valve cover. |
12-10-2021, 09:15 AM | #2 |
Rep 119
Not sure about the update part of your post but regarding the valve cover, how many miles does your car have? The PCV system is built into the valve cover and it's been known to usually go bad 70k miles and up. Mine lasted up to 96k before I started hearing the PCV squeal at idle. Once replaced, car ran much better and squeal was gone. For some, the valve cover cracks and begins to leak oil, even after just replacing the gasket.
12-10-2021, 09:28 AM | #3 |
Rep 2,565
12-10-2021, 11:50 PM | #4 | |
Rep 8
12-11-2021, 01:18 AM | #5 | |
Rep 135
Well the car has now about 150.000 miles, but I don't think I have this PCV valve, it's a diesel engine. Anyway, after a more thorough inspection, dealer said I also need to change all the 3 seals in the rear differential, also some seal/gasket on the transfer case, basically I am leaking from every possible place, it's like they were meant to last exactly 150.000 miles. Oh, plus an oil pan leak. Needles to say, I will have to pay around 2500 EUROS to get all this fixed next week. I am reluctant to fix the oil pan leak, because they said they basically need to dismantle the whole front axle, suspension, front differential etc. and it sound like a disaster, also the leak is minor, like barely noticeable. Anyway it is amazing how absolutely everything started to leak at one, at the 150k miles mark. They noticed all of this during the recall campaign for the EGR Cooler, last week, but none of these leaks were present when I serviced the car like 4 months ago it's crazy. |
