07-21-2021, 10:18 PM | #1 |
Rep 2
2018 X3 tailgate latch jammed with suitcase buckle
Hi - I have a 328i, but my son has a 2018 X3. They went on a trip and the tailgate shut on a buckle on a suitcase strap. The metal buckle is now jammed in the latch mechanism. This seems to have put the system in limbo - not really open and not really closed.
The tailgate isn't quite closed, so when you press the button to open it, it tries to close it. Of course it can't because the metal buckle has jammed it up. We found that there is a manual release under the cargo floor panel, but cannot raise the floor panel from the inside with the tailgate down. It seems to be one solid piece and hits the tailgate when trying to raise it. Does anyone know the trick to getting the floor panel out to access the latch override? Or perhaps how to fool the system into thinking the tailgate is all the way down so it will trigger the open cycle with the button? Thanks for your time in advance! Andy |
07-24-2021, 04:14 PM | #2 |
Rep 232
Have tried to manually force it down or pull it up with your hands. Try this while pushing /pulling the hatch button on the door. Good Luck
NKAWTG-N
07-24-2021, 06:29 PM | #3 |
Rep 1,933
Fold the rear seats down, lift up the panel a bit at end closest to the tailgate and slide rearward enough to disengage the other end of the panel and then lift/remove panel.
07-25-2021, 04:36 PM | #4 |
Rep 2
Thanks! I liked that way better - I suggested this to him, but I guess he couldn't get it where it needed to be. He ended up removed several of the panels back there to lift up the floor pan.
