12-06-2020, 06:17 PM | #1 |
Rep 10
Drives: 2011 BMW X3 3.5i N55 F25
Drivetrain Issues When Shifting into Reverse
I have a 2011 X3 35i N55 with 136,000 miles on it. When I first go to start up my car and back it out of the garage in the morning, it feels like the brakes are on. Most times when I shift the car into reverse it almost jumps and will not roll backward without heavy acceleration. There are no warning lights or faults on the dash. There is also nothing coming up on my Schwaben Multi-System Elite Scanner either. There is no issue putting the car in park or drive only when shifting it into reverse to back up.
So far I have replaced the transmission filter, drivetrain oil, and also heated the car up and shifted through the gears as they say to do after replacing these parts. Even after doing these things my issue still occurs. Any and all suggestions or past experiences with this or a similar issue would be greatly appreciated. Sincerely, Steve Beemer |
12-06-2020, 07:07 PM | #2 |
Rep 211
Your in the rust belt so make sure none of the calipers are frozen and that the contacts for the pads and brake pins are greased properly.. also check and make sure the electronic park brake actuates. These transmissions are pretty strong compared to bmw’s previous automatics, for your own piece of mind those transmissions whine extremely loud when low on fluid.
12-06-2020, 07:13 PM | #3 | |
Rep 10
12-06-2020, 07:15 PM | #4 |
Rep 2,564
Did the problem happen before or after you changed the trans fluid?
Exactly what steps did you perform to fill the trans to the correct level? Have you put the trans in neutral and roll backward to make sure the parking brake is fully releasing? |
12-06-2020, 07:23 PM | #5 |
Rep 10
The issue happened before changing the transmission filter and fluid. I changed these things in hopes of that fixing the problem. I drained the transmission fluid. Removed the filter housing. Installed the new filter housing. Torqued and tightened in order per the installation diagram. Then filled the transmission with a large syringe. Warmed the car up to the specified temperature. Removed the side fill plug when it was running at temperature and added more fluid until it started to come back out the side fill plug hole. Finally, with the car elevated, with my foot on the brake, I shifted through park, drive, and reverse three times, and then manually shifted through all 8 gears. I climbed under the car once more and topped off the transmission fluid. I have not tried to push the car back while in neutral. I will attempt this.
12-06-2020, 08:50 PM | #6 |
Rep 211
Sounds like you definitely used the correct method for the transmissions service. Did the fluid look good?
Try the pushing in neutral cold see if she feels like she’s rolling smooth. Just for piece of mind look up the throttle rest just Incase you have some weird adaptations going on or something Another question these cars have a hill hold mode. Is your drive way steep or the area you park in ? Perhaps this hill hold mode is engaging ?? Last edited by e30lover318i; 12-06-2020 at 08:56 PM.. |
12-06-2020, 09:05 PM | #7 | |
Rep 10
12-08-2020, 07:27 PM | #8 | |
Rep 10
12-09-2020, 06:09 PM | #10 |
Rep 10
I’ve owned it for two years no issues at all I really love this car the person before me was a older person and bye the looks of the car it was really taken care of. So my next thing too try will be lift the car up on all four wheels and check trans level remove side plug see if any comes out when car is running I’ve driven it enough and temps are where it should be circulated throughout the transmission I’ve ordered redline full synthetic transmission fluid and a bottle transmission seal conditioner this will make the seals swell hoping that it will make the transmission shifts smooth and then give me a reverse back I will keep you posted on the outcome thank you everyone for posting your thoughts
12-09-2020, 07:00 PM | #11 |
Rep 265
Do remember that fluid will drain from the fill plug is the car is off. Read the DIY on trans filling. Anyway, to top up it must be 40-50 deg c with engine idling in park. Be careful and good luck.
12-09-2020, 07:35 PM | #12 |
Rep 10
Thanks Dan
I just drove it around the block still shifting with a slight shimmer when coming to a stop. After she warms up I have reverse. Looking forward to lifting her up and checking the level of fluid. Yes I did bring it up to temp 40/50 C to finish filling her up I’m really hoping that changing the fluid to redline C4 full synthetic and adding the transmission seal conditioner from AC delco will make a difference. Thank you for your input it very much appreciative Steve Beemer |
12-09-2020, 08:21 PM | #13 | |
Rep 2,564
12-13-2020, 01:50 PM | #14 | ||
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
Shuttering in low speed is usually a transfer case symptom, not transmission. But sounds like OP might have issues with bad seals in trans. OP you can pour $10,000 on attempted "what if" fixes or take it to a reputable shop for diagnosis. You'll be better off getting an expert to find the problem, everyone here is only able to speculate at best since we can't physically be with the vehicle.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
01-22-2021, 06:12 PM | #15 |
Rep 10
Sorry for the long delay so I took the car to a transmission shop that does work on BMW I found a transmission with 44 thousand miles and replaced it. The owner said the trans was shot it had metal all over the filter pan so I guess it was the right call. I’m a happy owner of a 2011 m sport 335i that’s running great. Thanks to everyone that gave me advice.
Sincerely Steve Beemer |
