06-05-2019, 09:11 PM | #1 |
Rep 74
Plug n Play Xenon?
I'm curious if the f25 headlight assembly is interchangeable from halogen (current) to xenon
Would something like this be plug and play? Or, would wiring etc be needed? https://www.ebay.com/itm/2015-2016-2...QAAOSw0VBc1J0S Replies are appreciated |
06-05-2019, 09:25 PM | #2 | |
Rep 744
M3 E93
PORSCHE MACAN S: SOLD BMW X3 F25: SOLD AUDI S4: SOLD BMW E92 335: SOLD |
06-06-2019, 12:58 AM | #3 |
Rep 2
Yeah ! I was install xenon headlight on my 2017 model , it's work perfect fine. Do any one know how to get angel light work ? I don't need high beam. So far on decode said it is have light package so I believe don't really need to change a footwell module . Any one know it please help
06-06-2019, 06:25 AM | #4 |
Rep 11,857
Drives: MY24 G01 AW Msport
check idrive settings, it might be checked off. OR you will need to code few items for car to recognize new headlights installed.
06-07-2019, 02:26 PM | #5 |
Rep 56
Does anyone have any recommendations for upgrades to my halogen lights that doesn't require retrofitting anything, purchasing any extra equipment to prevent flickering, or requires me to code? I know Phillips makes some bright white halogen lights, I believe they're called Crystal Vision, and I've seen a few LED conversion kits that claim that don't need any coding or anything. Just wondering if anyone has upgraded their halogens that doesn't require too much effort, lol.
06-29-2019, 07:23 PM | #6 | |
Rep 117
07-01-2019, 05:26 AM | #7 |
Rep 352
Basically any halogen system is going to stay halogen without major modifications. Most vendors have good/better/best options. Here's the basics for selection criteria as to what is right for you.
1. Stay away from blue tinted bulbs. Here's a couple of articles on that. https://www.danielsternlighting.com/...blue/blue.html 2. Brighter lighting is achieved by the amount of xenon gas in the halogen capsule among other things. Don't confuse this with HID lamps that also use xenon gas. (This is why I don't call HIDs xenon lamps.) 3. Brighter lights mean shorter lifetime. Vendor "best" lights have very short lives and cost significantly more. I generally go with "better" to balance cost vs performance. An additional tech article on "superwhites" https://www.danielsternlighting.com/...uperwhite.html |
pungo899.50 |
07-01-2019, 06:55 AM | #8 | |
Rep 56
07-06-2019, 05:08 AM | #9 |
Rep 3
Did you finish your upgrade to LCI? Changing light modul is necessary or not?
07-06-2019, 07:51 AM | #10 | |
Rep 71
Check out my pics in this thread: https://x3.xbimmers.com/forums/showthread.php?t=1501670 Edit: I see you also don't want to code. These will still work without coding, it'll just pop a warning on your dash saying there is a malfunction with your low beams. It's annoying, but doesn't stop them from working. I used Carly to disable the bulb resistance checks. Last edited by Iowa X3; 07-06-2019 at 07:56 AM.. |
07-06-2019, 10:13 AM | #11 | ||
Rep 56
07-06-2019, 11:39 AM | #12 |
Rep 287
Those that have anti flicker is just built-in resistors. But be warn they will run hotter. Best thing to do is code the LED bulbs, thus cooler running temperature.
07-06-2019, 11:57 AM | #13 |
Rep 56
07-06-2019, 12:02 PM | #14 | |
Rep 71
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Would highly recommend getting LED's for your parking/DRL's as well, so the color and brightness of them will match your LED headlights. You can see the difference in them in that thread I linked to earlier. BTW, be wary of the reviews on Amazon. People are using these in many different makes and models of cars and trucks and some of them probably aren't reacting very well to their vehicles. I can tell you I've never had an issue with them in almost 3 years of running them in my X3. I even went ahead and bought the high beam LED's from them so they match (they're the same H7's). |
07-06-2019, 12:52 PM | #15 | |
Rep 287
E-sys is a free tool but not the easiest for a beginner or novice because if you don't have experience you can create havoc to your vehicle's ecu. Bimmercode and carly for bmw are the easiest because they provide graphical user interfaces to code your car but also have additional features to expand hidden features for your car. If you can navigate windows or apple's ios then you're be okay. I suggest bimmercode app but will cost you to purchase the app and a wifi/bluetooth obd dongle. Cost is about $50-$60 for both, depending if you're getting android or ios version. Carly app changed their cost to subscription rates and now charges annually. Of course you need a android or apple device (phone or tablet). You can get better led bulbs without the additional cost for those anti-flicker canbus units they charge. The point is coding is the best way to add led, add additional features to your car, etc... When you're serious and want to code, shoot me a Private Message and will provide guidance after you buy the app and dongle. Its easy to use and you'll be happy on your purchase. |
07-07-2019, 07:35 AM | #16 | ||
Rep 56
07-07-2019, 07:37 AM | #17 | ||
Rep 56
07-07-2019, 11:22 AM | #18 |
Rep 2,564
Curious how these LEDs work out for you. In general, aftermarket drop in LEDs have less throw than Halogen which can make a difference as speed increases. Also, the glare to oncoming traffic can be a bit harsh, you'll know if you get flashed allot.
I recommend to only install it on one side then go for a drive to compare the difference. Excessive foreground light might seem good since you can see things close in front of you but you loose distance vision. These LEDs keep getting better so I'm curious how they are working for people with regard to usable light on the road without blinding oncoming traffic? Last edited by pungo; 07-07-2019 at 12:07 PM.. |
07-07-2019, 12:22 PM | #19 | |
Rep 71
