11-23-2018, 05:35 PM | #1 |
Rep 84
Alarm started going off randomly
This morning i was woken with my car alarm going off lights flashing, checked it out, no codes, no one tried to break in, so reset and then back to bed, then 15 minutes later the alarm went off again, again reset and it was fine.
Has been fine the rest of the day and got home today after a long drive, and again alarm went off after being home about 20 minutes. I have been doing some reading, and 2 culprits seem to be the hood latch or the battery is on its way out. I tried to locate the hood sensor, however i could not find it. Anyone point me in the right direction as to where it is located, and how i can test that it is functioning correctly. I also read that cleaning the sensor with brake fluid should do the trick. There are no codes or errors shown, and nothing to show the hood is open either. Is there a way you can get a code from the alarm or get it to tell you which sensor triggered the alarm ? Last edited by 94vtirozguy; 11-23-2018 at 05:52 PM.. |
11-23-2018, 09:29 PM | #2 | |
Rep 540
Drives: 2016 BMW X3 35i M-Sport
I think that if it was the hood sensor you'd get a light on your dash showing that the hood was open. I'd test your battery. I bet there is a way to get alarm logs or something like that, I'll do some digging and post back with what I find.
Good Luck! don't piss the neighbors off too much Quote:
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others Instagram @TheCoolX3 |
01-16-2019, 04:07 PM | #3 |
Rep 84
As a follow up to this. I ended up replacing the battery. After battery replacement, i cleared all the codes.
Now i have 3 codes still, and the alarm still randomly starting to go off again in the last two days. JBE Junction box eletronics - C90C85 - rain-light-solar-fogging sensor hardware fault, rain sensor (permanent) FZD Function centre roof - 801A4C - SINE: under voltage detected in internal voltage supply (intermittent) IHKA Integrated automatic heating/air conditioning - E7144D - signal (rain intensity, 0x226 invalid transmitter JBE (permanent) To me it looks like the rain sensor possibly needs to be reset after battery change ? or it has died. The 801A4C code however got me stumped and would have thought that the battery change would have resolved this.....or is this another initialization thing needed to be done for the moon roof ? Also the alarm randomly going off, is also an issue. |
01-16-2019, 06:34 PM | #4 |
Rep 5,115
Maybe a mouse hiding in the vehicle - hides while you're in the car - gets active as soon as you've locked the car. He starts moving around and sets off the inside alarm.
Yep. It's happened.
01-17-2019, 06:13 PM | #8 |
Rep 84
yeah i looked at pulling it apart and seeing if it is a wiring issue. Also looked at the reset procedure for the sensor.
Might give them a look at first. but would this cause the alarm to go off ? |
01-18-2019, 01:52 PM | #9 | |
Rep 7,584
(SINE = emergency power siren and tilt sensor)Here's a direct link to the TIS that explains the SINE (interior motion sensor): https://www.newtis.info/tisv2/a/en/f...right/HI6lx4TC Are you leaving any windows or sunroof open while the car is parked & locked? BTW, I don't follow the X3 that much so I'm not that familiar with the engine nomenclature vs the model/engine suffix...since you don't indicate which model X3 you have...you can click the HOME (at the top left of the TIS website) and select the correct X3 model...or use the last 7 digits of your VIN...this will set the TIS site to give links/results based on your VIN or model. You can then type SINE into the search box and it will list the correct info for your model X3.
01-18-2019, 04:41 PM | #10 |
Rep 84
Yeah i double checked to make sure all windows and roof were shut.
Model is BMW F25 X3 xDrive28i SAV. The site has some useful information thanks. Last edited by 94vtirozguy; 01-18-2019 at 05:12 PM.. |
01-18-2019, 09:01 PM | #11 |
Rep 84
i can confirm that if i lock the car and then hit the lock button again (within 10 seconds), then the alarm does then not randomly go off.
So my understanding this is disabling the motion and tilt sensors but not the hood sensor. Therefore it takes a faulty hood sensor out of the equation. How do i test the tilt sensor to see if it is faulty ? |
01-19-2019, 07:02 AM | #12 |
Rep 45
This may be a long shot, but it happened with my car. Mine was acting very similar to yours. Took it to the dealer and they found nothing, about 30 minutes after I got home my alarm went off again so I called the dealer and drove back (45 minute drive). They asked me to bring both keys with me when I came back, Final result, a new key. Seems like one of the buttons on my wife's key was stuck down causing the system to stay active and draining the battery. Dealer charged the battery and replaced the key. No issues since !
Doug
2019 BMW 430 XI Grand Coupe, White, Black leather interior 2016 BMW X3, 28d, Mineral White metalic, Oyster Nevada leather interior. |
01-22-2019, 10:39 AM | #13 | |
Rep 7,584
You can read about it at this link: https://www.newtis.info/tisv2/a/en/f...ensor/D1gc5KAz This link details where the alarm siren/tilt sensor is located and how to access it: https://www.newtis.info/tisv2/a/en/f...ystem/F0PCS9mj The following graphic shows an example of a siren with a tilt alarm sensor.
06-27-2019, 09:14 AM | #15 |
Rep 540
I've noticed this more and more on this forum and some others, as the weather warms up, all the funky electrical issues disappear.
I wonder why that happens, so odd!
08-28-2020, 03:53 AM | #17 |
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
More likely a battery issue. Battery performance drops the colder a battery gets.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
02-13-2021, 03:47 PM | #20 |
Rep 84
there are /were no codes being thrown to indicate anything out of ordinary. I am now thinking it could be the change in air pressure in the car when it gets really cold at night.
What i tried this cold season was i changed the air system recirculation mode in the car to not recirculate internal cabin air but to take air from outside. So far this cold season i have not had the alarm going off randomly at all and it has been colder temperatures. Nothing otherwise has changed in the car at all. |
02-13-2021, 04:47 PM | #21 |
Rep 434
Thanks for the fast reply!
Is your car parked outside in the winter? I'm in Mass, and i do park in a garage, but the garage hovers around 40 degrees in the winter. Admittedly, my car is usually 78-80 in the cabin when I pull in from driving home, it could happen. For me, the car was in the garage close to 22 hours before the alarm went off. I do usually leave my windows open a little bit, and last night I didn't though.... hmmm. Last edited by SharpAndCunning; 02-13-2021 at 04:55 PM.. Reason: found anwser in profile 2013 |
