08-08-2018, 12:13 PM | #1 |
Rep 818
Thinking about upgrading it to a mSATA drive with an adapter to dramatically decrease boot up speeds when turning the car on. Has anyone done it here? Seems simple enough.
08-08-2018, 01:35 PM | #2 |
Rep 3,651
Haven't seen much on the X forum side but I know for the 1 Series people have made it work but it was more difficult than expected. It seems you need to not only be computer literate (I think of myself as pretty good at building and troubleshooting PC's, networks, and so on) but additionally have a running Linux device and be fluent at the commands as well. The reasoning was to ensure you performed a perfect clone of the original drive, it didn't look to be as easy as it sounded and the more common windows (not just oem ms but 3rd party as well) software didn't seem to quite be up to the task.
Stating the obvious whatever works for any other BMW of a similar vintage and entertainment system type (i.e. CCC based) should work for the X3 as well. Maybe there is an easy route that just hadn't been performed yet as of the last time I checked into it. |
08-08-2018, 01:51 PM | #3 |
Rep 818
I'm a career linux programmer, don't be scared of it, linux is simple.
BUT To make your life even easier, don't go by any of those crazy write ups there's a much easier way. Snag a copy of the Acronis True Image bootable CD that runs off linux and boot to that. It will copy the BMW HDD's QNX4 file system which is native to Linux bit by bit in a nice GUI screen to the new SSD, no command line codes required. Soooo easy. |
08-09-2018, 08:29 PM | #5 | |
Rep 3,651
Anyhow, sounds like you know what to do, go for it. |
08-10-2018, 05:07 PM | #6 |
Rep 254
Looking forward to seeing an F25-specific write up for doing this. I think I'm good on the cloning part but I'm always afraid of breaking things when I pull panels off.
08-17-2018, 02:35 PM | #9 |
General of the Space Forces
171
Rep 723
Which options make a difference to the hard drive? I can see it might make a difference in size of the hard drive, but not the type/connection/etc.
My X3: MY2011; HUD; Nav; Bluetooth; XM; back-up cam with topview; usb; |
08-19-2018, 07:50 PM | #11 |
171
Rep 723
ok, IDE...any idea of how big the drive is? Is there just one drive for nav/multimedia/etc? SSDs are getting cheaper, tempted to upgrade.
08-22-2018, 12:16 AM | #12 |
Rep 360
I bought the hard drive that was referenced in the X5 thread (linked herein). It looked straight forward enough to copy the hard drive data over. I'll post the results.
Generally I'm okay with the content on the CIC vs. NBT, but the load times and lag on the CIC can be annoying. If this speeds the system up in a meaningful way for $100, then I'll be happy enough.
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
08-24-2018, 10:58 AM | #14 |
171
Rep 723
I just ordered an mSATA drive, IDE adapter case, and IDE to USB cable. Just need to find the DIY to open up the console, looks different than the X5 in the link.
08-24-2018, 11:32 AM | #15 |
Rep 287
Check out YouTube for BMW f25 Android navigation. They show how to dismantle and to get to the head unit.
