05-06-2015, 12:07 AM | #1497 |
Rep 91
VO activate FA which shows Vehicle profile.
Read SVT and go to SVT->HU_NBT->Read Coding Data-> Update whatever necessary -> Save and back to Export /Coding and the Code FDL. What do you mean VO Code Head Unit? isnt FDL coding HU_NBT consider VO code? Sorry i am still totally a newbie with this.... |
05-06-2015, 12:12 AM | #1498 | |
Rep 41,224
Drives: 2018 Alpina B6 650ix GC
Right-Click on HU_NBT, and select Code.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
05-06-2015, 12:19 AM | #1499 |
Rep 91
Code with right click on HU_NBT and got error message
Caused by: Errors during NCD generation for CAF cafd_00000ded-003_013_025: DataGroup HMI, Function LANGUAGE_1: More than one condition parameter is active: [chinesisch_simp, english_us] DataGroup HMI, Function LANGUAGE_2: More than one condition parameter is active: [franzoesisch, chinesisch_trad] DataGroup HMI, Function LANGUAGE_3: More than one condition parameter is active: [english_uk, spanisch] DataGroup HMI, Function LANGUAGE_MASTER: More than one condition parameter is active: [english_us, chinesisch_simp] DataGroup SYSTEM_EINSTELLUNGEN, Function DEFAULT_DATUM: More than one condition parameter is active: [mm_dd_yyyy, yyyy_mm_dd_slash] Timestamp: Tue May 05 22:17:09 PDT 2015 SessionId: default ErrorCategory: SYSTEM_ERROR ID: 303 |
05-06-2015, 12:39 AM | #1501 |
Rep 91
I was able to remove 866, write FA without 866, then read SVT and VO code back to HU_NBT and it comes back without error message.
I will try again tomorrow with 866 again. Shawn, just to clarify. my intend is to change the iDrive menu Under settings to have more language (English/Spanish/French). My iDrive currently display Chinese characters in Media or Phone mode no problem, but i am trying to change the menu to Chinese so my father-in-law can understand... Last edited by ecsw; 05-06-2015 at 01:03 AM.. |
05-06-2015, 04:53 AM | #1502 | |
Rep 41,224
05-06-2015, 10:14 AM | #1504 |
Rep 41,224
I am not going to check all your Option Codes for you. That is your job.
05-06-2015, 02:11 PM | #1505 | |
Rep 91
Correct me if I am wrong. A conflict code as 866 should be replacing another FA code? Is there a reference that I can look up to find out what FA code means? I understand replacing 6NH with 6NS will give me the enhanced BT and Office. So to follow this theory, I should be replacing 866 with my existing Language code? How do I know which one is a "language code"? Is this reference valid on F25? http://www.e90post.com/forums/showthread.php?t=717103 Last edited by ecsw; 05-06-2015 at 02:17 PM.. |
05-06-2015, 02:30 PM | #1506 |
Rep 91
Shawn, looks like I am on the right path.
Existing Code 853 is English, I should replace it with 866 and give it a try again tonight. FA code are interesting.... They even code "THROUGH-LOADING SYSTEM"? |
05-06-2015, 02:38 PM | #1507 | |
Rep 41,224
05-06-2015, 03:03 PM | #1508 |
Rep 91
Thanks to all your help, you are truly the master!!! Now here are more stupid questions for you. I noticed in the coding database there is an option described as "Sport + Modu acma" for ICM 3000. Does that mean I can turn it on so I can have Eco/Comfort/Sport and Sport + on my F25? Or was it for something else? HU_NBT has option High_Bean_Assistant on and off. If I never purchase that option, can coding make this happen or it requires extra hardware/accessories? |
05-06-2015, 03:06 PM | #1509 | |
Rep 41,224
You cannot enable HBA without hardware, either FLA or KAFAS Camera, and SZL Stalk Switch.
05-06-2015, 03:07 PM | #1510 | |
Rep 113
Drives: E90 320D, F25 X3 30D
05-06-2015, 03:08 PM | #1511 | |
Rep 41,224
05-06-2015, 09:15 PM | #1512 |
Rep 91
Shawn,
FA replace 853 with 866 VO code HU_NBT no more error message. However, all the iDrive display are gone. i tried getting into Setting and change language but I couldnt select anything in Language. FDL code HU_NBT with language to Chinese_Trad/Sim and change Language_Master to Chinese_trad but still no luck. I FA it back to 853 for now. I remember seeing someone else having similar problem, but I am not sure how to fix or what other settings need to be updated.... It looks like this from BimmerFest http://www.bimmerfest.com/forums/sho...d.php?t=646514 Last edited by ecsw; 05-06-2015 at 09:24 PM.. |
05-06-2015, 09:17 PM | #1513 | |
Rep 41,224
05-06-2015, 09:27 PM | #1515 |
Rep 41,224
05-06-2015, 10:01 PM | #1517 |
Rep 41,224
Exactly. I have posted many times on how to flash with E-Sys.
05-06-2015, 10:08 PM | #1518 |
Rep 91
