02-07-2015, 06:35 AM | #1321 | |
Rep 41,224
Drives: 2018 Alpina B6 650ix GC
It is pointless to back any ECU Data up as it can be reset simply by VO Coding the ECU with original FA.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
02-07-2015, 09:09 AM | #1322 |
Rep 260
OK,
I have the cable, have the SW installed, get connected to the car .... Now what I can not do is reading the CAFD's so they get saved on my laptop. "Select CADF (only one with a green Check mark) file under the module you want to read and select “Read Coding Data”" : page 6 of getting started coding.... I do not have/see the "read Coding Data" when I select a green CAFD What do I do wrong? |
02-07-2015, 11:48 AM | #1323 | |
Rep 41,224
If CAFD is present, you have already Read Coding Data. Now just right-click on CAFD and select Edit FDL.
02-08-2015, 07:51 PM | #1324 | |
Rep 859
Disabling sidemarkers
FRM / 3060 FRM_U_EFFEKTIV, 20 / U_EFF_F25_BKL_gedimmt change wert to Wert_03__aus. give it a shot. |
02-09-2015, 03:40 PM | #1325 |
Rep 113
Drives: E90 320D, F25 X3 30D
Hey,
Can someone help me with what all I need to code to enable sports auto (2TB)? Do I need to change the VO also? And what about launch control? These will be the first things I code ever, so do give me instructions in a simplified manner please |
02-10-2015, 07:57 AM | #1326 |
Rep 74
Question... has anyone been able to find the section for the towing "software update" that BMW does? I was under the impression that everything the dealer does could be found in the settings, but I have yet to find the PDC controls for the 7-pin adapter.
02-13-2015, 03:29 PM | #1327 | |
Rep 113
If I change the VO in the salapa element it will code the GWS/ICM itself? So I won't have to code them for sports auto after? If it gives me an error like you mention above, can I just clear it and code the gws/icm? Also if I don't change salapa element and I just code gws/icm, will the shifting behavior change? I don't want to enable paddles. Lastly, do I need to code ICM also? Ive seen conflicting posts in different forums, some give some values to be changed in ICM, while you say GWS is enough? Thanks a ton for any help. |
02-13-2015, 03:59 PM | #1328 | |
Rep 41,224
If it gives you an error, load original FA and VO Code the car. You should not need to code ICM.
02-16-2015, 08:17 AM | #1329 |
Rep 113
So coded my car today finally. Changed 2TB in the FA. Then coded FDLs and activated launch control, the other 2 things in EGS were already active. Coded the ICM too, and deactivated S205A and activated 2TB. Haven't driven it properly, but in sport + and manual mode the car hit the rev limiter and didn't shift up, so that is a sure sign that the coding is working.
Also tried coding an F30, but there wasn't any F30 option when connecting from Esys, do I need more files for F30 because all the other series were there? Anyway chose F20 and coded a few small things on it. Big thanks to Shawn and other pros like April1 whose guides have helped me. p.s - Also had an issue connecting to FRM, where some cafd was missing. Got the link on another forum and will try with the file I downloaded tomorrow. p.s 2 - When trying to change the logo in Kombi there was BMW_logo which I made mpm, and then another mpm_logo which is still BMW. Should I change this too? Also planning on trying the X-Drive status tomorrow. |
02-16-2015, 08:57 AM | #1330 |
Rep 41,224
F30 uses F20 Target.
02-17-2015, 11:25 PM | #1331 |
Rep 113
02-17-2015, 11:32 PM | #1332 |
Rep 41,224
Yes, it should not be an issue.
02-18-2015, 08:45 AM | #1333 |
Rep 255
Is there any coding that can default the dash display (speedo / tach, time etc) to white rather than BMW Orange?
I have a 2014 X3, and have a difficult time seeing the orange as I have a bit of red-green color blindness. |
02-20-2015, 08:31 AM | #1334 |
Rep 113
So I couldn't find the start stop memory settings in my car, nor the settings for the doorhandle LEDs to come on in reverse.
For the start stop memory I looked in FRM, like mentioned in F10 cheatsheets, and for the reverse handle LEDs too. Where can I find them? Also I activated the X drive display, but the compass doesn't work, and of the 3 values mentioned at the bottom only the 3rd one works while the other 2 show --. Lastly is it safe to enable coasting, or were there hardware changes for it? I checked the part number of my gearbox on realoem, along with one of the newest production date and the part numbers were the same. |
03-01-2015, 01:14 PM | #1335 |
Rep 95
Hi Guys!
Long time waiting for the cable, but finally arrived. I started the process, and after installation of <E-Sys Launcher Premium> program my antivirus software found a virus Trojan.Gen.2 and removed the <esyslauncher.exe> file. Did this happened to any one else? Is it possible that it has this malware? Got surprised and didn't know to do. Can someone advise what shall I do? Tks in advance |
03-01-2015, 01:47 PM | #1336 | |
Rep 41,224
03-01-2015, 02:09 PM | #1337 | |
Rep 95
So, I can use the file safely, isn't it? However is it possible to get the 1.0.7 version? |
03-01-2015, 02:16 PM | #1338 | |
Rep 41,224
PM sent.
03-04-2015, 05:30 PM | #1340 |
Rep 95
Can I use the same token to code another F11?
I still haven't started to code mine because now it's in the BMW for a warrantie complaint. They told me there are software updates for my 2012 F11 but it costs €115. I wonder, if the changes are worth it... Can someone tell me which they are? They lend me a 2014 F11 with NBT software and I noticed major differences between this one and mine (CIC). Could the CIC updates be close to that one? Thanks in advance! |
03-04-2015, 05:33 PM | #1341 | |
Rep 41,224
CIC can never look or act like NBT. Latest CIC Firmware won't provide any noticeable difference.
03-05-2015, 03:19 AM | #1342 | |
Rep 95
Nevertheless I read somewhere in this thread that the new revision (I think v52.4) will accept coordinate input in the nav system. At least is this for sure? How can I verify my F11's software version? |
