11-28-2014, 12:34 PM | #1189 |
Rep 81
Drives: X3 F25 (2011), X5 F15 (2017)
11-30-2014, 05:00 PM | #1190 |
Rep 6
11-30-2014, 07:07 PM | #1191 | |
Rep 41,229
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-01-2014, 01:51 PM | #1192 | |
Rep 81
mine is 2011 and I have 3 modes to select- Normal, Sport, Sport+ My friend's 2013 has EcoPro, Normal, Sport. As he said, EcoPro usable for pensioneer only, not why we bought beamer... |
12-01-2014, 06:36 PM | #1193 |
Rep 55
Enhanced Bluetooth will get you the full BMW Office functionality...
2015 X3 xDrive35i Space Gray: ZDA | ZDB | ZPP | ZTP | Heated Seats | 309 wheels | coded
12-02-2014, 07:13 AM | #1195 |
Rep 41,229
PM sent.
12-02-2014, 03:21 PM | #1196 |
Rep 4
Need help with coding F25 X3...EPS stopped working
So I was coding a buddy's F25 X3 with a refurbished EPS unit. All was working and car was driving except it did not have CAFD values inputted for the EPS unit. I went to code in the CAFD values for the EPS ECU but I mistakingly entered the wrong values and it accepted it, but now the EPS unit stopped working and car only drives now with rough physical manual effort. Current Integration I-Step is (F025-13-11-502). I've since gone back in to re-code in the correct CAFD values for the EPS and it is saving the correct EPS values, but its still not working. Is there any way to fix this situation?
Any help would be appreciated. April1 or shawn, anyone?? Thanks guys. |
12-02-2014, 03:42 PM | #1197 | |
Rep 41,229
12-02-2014, 08:16 PM | #1198 |
Rep 95
my god, so many pages to thumb through. i have a question, and i promise to keep it simple.
first, thanks to everyone for providing great info. after reading most of it i decided to jump into the coding game head first. i picked up the cable, downloaded the software & purchased a token and immediately went to work. i have since coded almost everything you can code on my 14 X3. one thing i can't do, and may never do with coding, is to get video playback on ipod/iphone w/o the media snap in adapter. I have an iphone 6 so buying one is not really an option. i am now using my trusty 160gig ipod classic for storing music and movies. I can obviously play music via the usb but can't play video for the life of me. I believe I have activated (or should I say Aktiv) everything that could or should be active. When connected, i can look up the movie list in idrive, I can select it for play, and it does play but only sound comes out. there must be a setting somewhere that will allow it to transmit video. can someone help? btw, i tested a Samsung Galaxy S5 and when connected to the usb i can play both music and videos/movies with no problem. comments???
2019 BMW X7 M-sport
2017 Harley Street Glide Special 2018 Triumph Bobber Black |
12-03-2014, 10:51 PM | #1199 |
Rep 54
Guys, I just read the first post of this thread. After doing the initial factory setting back up... in the later steps, it was mentioned that after eat FDL code, the CAFD file should be backed up again. Am I reading it correctly? Are you just backing up that one particular file, or are you backing up the whole system with that single code change in place now? Just confused.
My thinking was to just do the factory back up. Code one item and then test. And then move on to the next code if sucessful. Can't really see the purpose behind backing up after each and every single change. Can someone clarify? Thanks! |
12-04-2014, 04:52 PM | #1200 | |
Rep 41,229
12-04-2014, 07:10 PM | #1201 |
Rep 95
interesting.. how do you VO code it back to factory default?
i kind of lost track of all the changes i've made. everything works, but i'm concerned that maybe i may have to do a restore later in the future. do you guys restore before bringing it in for service? if not, has the service center noticed and/or gave a sh##$?
2019 BMW X7 M-sport
12-04-2014, 07:22 PM | #1202 | |
Rep 41,229
I don't worry about dealer service. They don't care if car is coded.
12-04-2014, 08:05 PM | #1204 |
Rep 41,229
It's not.
12-05-2014, 03:30 PM | #1206 |
Rep 41,229
PM sent.
12-07-2014, 02:28 PM | #1207 |
Rep 3
First, thank you to Shawn and all the others here for all your hard work and continued attention to this. I just got done coding several things on my 2012, a few of which were always very frustrating! (most of all the TPMS display!)
I coded: -Unlock all doors with engine off -Electronics off when door opened -Close mirrors/windows/sunroof from FOB -Added low beam headlights and fog lights to my welcome lights -Close trunk from FoB and Kick panel -Enable sports display Enable full text lines -Add Temp/PSI to tire screen -Remove legal disclaimers -Show digital speed in cluster A few questions: -I did search through and it seems there is no way to "auto fold mirrors on turn off", if this isn't true, please let me know, I always fold them so this would be handy -I couldn't find VOLUME_POPUP_DISPLAY to show the volume on the display, would it be under a different name? -I did enable SPEECH_2_TEXT but still am not able to speak emails or texts, I must not have the appropriate hardware. I didn't end up "decoding" this, I'm assuming I can leave it and it won't matter since it doesn't do anything for me. -the sport display, while neat, doesn't look very accurate. I goosed it a little and it went up to 400 ft-lbs. Now, while I do wish I had that kind of go, I know my 28i does not. -Is there a way to have the seat belt chime shut off after a certain amount of time? It seems to just keep going. I don't want to completely disable it for when I do have passengers, but when my dog rides on the front seat I'd like to have it stop after a few chimes. -Is there a way to have the RDS song info scroll through when on the radio screen without going right clicking on each station? I do not have Nav, just the small screen. -I can already stream bluetooth audio via my cell phone to the car, will going in and enabling enhanced bluetooth add anything? |
12-07-2014, 03:41 PM | #1208 | |
Rep 41,229
VOLUME_POPUP_DISPLAY requires 609 Navigation Professional with new NBT Head Unit and with at least 50.4 firmware. SPEECH_2_TEXT requires 609 Navigation Professional with new NBT Head Unit, and a 9F FSC Code, and it is a subscription service via Nuance's Dragon Drive: http://www.nuance.com/for-individual.../bmw/index.htm To change the duration of the seat belt warnings, try coding thees: ACSM => GWF_IW_DAUER = Werte As Desired ACSM => GWF_SBR_WARNDAUER - Werte As Desired The count is in 0.5s steps (i.e. 0C HEX = 12 Decimal x .5s = 6s). You cannot change RDS display. If you can stream Bluetooth Audio in a 2012 build, it seems you already have Enhanced Bluetooth. What is your Bluetooth Option code?
12-09-2014, 11:58 AM | #1210 |
Rep 41,229
PM sent.
