04-09-2014, 01:07 PM | #947 | |
Rep 41,221
Drives: 2018 Alpina B6 650ix GC
http://www.f30post.com/forums/showpo...postcount=1403
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-10-2014, 09:44 AM | #948 | |
Rep 85
Drives: 2022 X3 M40i
04-10-2014, 09:52 AM | #949 |
Rep 41,221
Well, after you read the cars VCM's, just tell me the I-Step current for each one, and I will tell you what the minimum PSdZData is needed for them.
04-22-2014, 10:55 AM | #951 |
Rep 344
Drives: 2017 m4
I have coded my f25 in the past and just had a service done where my daten files will not work. After doing extensive research, it looks as though i need 51.3 and a new version of e-sys. can anyone confirm this and/or send me to the right place where i can download?
I can connect via the vin and can read the ECU, but i can not edit FDL and get an error (which after doing research) signifies my daten files need updating. thank you all very much |
04-22-2014, 11:50 AM | #952 | |
Rep 41,221
PM sent.
04-23-2014, 01:31 PM | #953 |
Rep 85
Shawn, my wife has decided to trade her 2011 F10 on a 2014 F32 (435i), What software will I need to code this vehicle? I will assume the current cable that I got from April 1 will work. Build date on the new vehicle is 3/10/2014.
04-23-2014, 01:34 PM | #954 |
Rep 41,221
You need the latest 52.2 PSdZData and E-Sys >= 3.23.4.
04-26-2014, 07:13 PM | #955 | |
Rep 165
Thanks again to Shawn and all the trouble shooting from Eli! Cheers |
04-27-2014, 11:43 AM | #957 |
Rep 41,221
PM sent.
04-30-2014, 04:17 AM | #958 |
Rep 233
Last January I downloaded PSdZData Lite Ver 51.3 and E-Sys ver 3.24.3 but then got distracted by other things and did nothing else.
Please help with three questions: 1-Are both these sets of files still valid? 2-What is a recommended reliable and trusted source to buy a cable? 3-What is a source to buy the required token? I am only going to recode only two parameters; TPM to show pressure & temp & the digital MPH display. If there was someone experienced convenient in central NY I would probably just ask them to help but there does not appear to be so I am going to do it myself. |
04-30-2014, 05:55 AM | #959 |
Rep 41,221
So long as your car has <= 51.3 on it, yes, they are still valid.
PM sent for cable and Token solution options.
04-30-2014, 09:43 AM | #960 |
Rep 2
Coding Blind Spot
My 2015 X3 28i is a week old. Super super. But the Blind Spot monitor is set up to work only after the turn signal is pressed. Set up for imbeciles.
HOWEVER once in Stop and Go Adaptive Cruise mode (new in '15 in the X3 a fantastic application everyone should get) the Blind Spot Indicator works as it should, i.e., whenever a vehicle enters the blind spot area it lights. No turn signal activation needed. QUERY. Is there a Code change that will bypass the turn signal requirement when not in Cruise Control mode. In other words making active blind spot monitoring the default. Thanks. |
04-30-2014, 03:33 PM | #961 |
Rep 233
It has been my understanding it is best the engine is running so battery capacity is not challenged. The instructions at the beginning of this thread state:
Connect E-Sys to your Car: 1.Connect ENET cable between car's OBD port and network port of laptop. 2.Switch on the ignition of the car, don't start the engine. 3.You will notice laptop tries to connect .... So, when is it OK to start the engine? |
04-30-2014, 04:59 PM | #962 |
Rep 41,221
Those are very old Instructions.
Start motor, connect cable to car and then laptop, wait until laptop gets IP Address, and then launch E-Sys.
04-30-2014, 08:58 PM | #965 |
Rep 41,221
PM sent.
05-01-2014, 03:48 PM | #967 |
Rep 41,221
05-01-2014, 10:16 PM | #968 |
Rep 233
True Speed Indication
I was surprised when I noticed the speedometer reading exactly matched a handheld GPS reading. That made me think the speedometer uses the GPS for speed input. Is this indeed so or just coincidence?
I was just doing some Google searches for a parameter to extend or eliminate the rear window heater time to off delay when I stumbled into the following two items available on the one series. True speed in digital speedometer KOMBI BC_DIGITAL_V_KORREKTUR nicht_aktiv = true speed True speed in analog speedometer KOMBI BC_V_KORRECTUR nicht_aktiv = true speed Does anyone know if these parameters exist on the F25? I am waiting for my cable to arrive so I can activate the TPM pressure/temps and digital speed indication. It would be nice if both the digital and analog speedometer read the accurate speed from the GPS. |
